My iMac didn’t have rear door to replace ram. What should I do
Replacing ram in 27” imac
If the iMac does not have an access panel replacing the RAM is difficult. You can see in Step 7 of this teardown that the RAM is installed on the backside of the main logic board. To access this you need to remove the display and remove the logic board. This is not an easy repair but it is doable with caution.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 10
過去 30 日: 10
今までの合計 35
