If fan in noisy, does it need replacement?
Some time, the fan on my Mac pro works very fast and it's noisy also. Do I need to replace the fan?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Could be that you just have some dust built up on the heatsinks, which causes the computer to run hotter, which in turns causes the fans to kick up. Pop open the sides and see if it's dusty. Anyway, no a loud fan does not mean you need to replace it, if you manually adjust the fans on an iMac it will sound like a jet.
このアンサーは役に立ちましたか?
The first thing you should try is reset the SMC . All you have to do is unplug the computer from the power source ( back of the computer power cord) wait 15 to 25 seconds just in case you count to fast. Plug it back in and RESTART the the computer the fan should reset back to normal. If this trick does not work then the fan is probably dirty and needs to be cleaned or it may need to be replaced. ( Always Try the simple things first ) like going to ifixit.com and ask a question.
I had a very noisy fan for a long time. Sometimes I could tap it and get it to quiet down. The "genius" bar folks said it was probably a foreign object that had been sucked into the fan.
I finally replaced it and it is a joy to not hear it.
From my experience, the answer to your question is "No, you don't need to replace it." On the other hand, if you do replace it, you may greatly enjoy the beautiful silence that will result. It is a VERY easy repair.
--Kenoli
このアンサーは役に立ちましたか?
POSSIBLE SOLUTION:
I have a MacPro 3,1 (Mfg Sept 2008) which I have used from 18 to 20 hours a day since it was new. A month ago it started having noisy intake fan issues (the dual fans at the front of the computer). At first I thought it was a harddrive issue, but after replacing all my harddrives with Intel Sata 3 SSDs (Speed Demon 520s, which make NO NOISE at all) I realized it was Fan Noise (sounded like they were out of balance during a cold boot).
Well, to make a long story short, the problem appears to have been a nearly dead CR2032 battery. At least the problem has not reoccurred or recurred again since replacing the 3 1/2 year old lithiums. It is at least worth a try if your battery is several years old.
Fan Noisy and sounds wobbly prior to the boot "Chime" (Bong) then it smoothes out.
Discovered that my APC UPS backup power supply was defective and not generating smooth sine wave and/OR it was distorting the sine wave AC being fed to the computer.
このアンサーは役に立ちましたか?
Okay, a further update. While the out of balance start-up fan noise temporarily stopped for awhile. Now she is back, and it is not the APC power supply nor is it the dual fan assembly in the front. It is, also, not dust, as I used compressed air to keep dust out of my Mac Pro. So I stuck a part of a small six inch piece of heat-shrink through the back of the aluminum cage into the rear exhaust fan during boot and the noise has gone away again. I will be replacing the rear exhaust fan in the near future and will report back. BTW don't try to replace any Mac fan without replacement mounting grommets, which you can get from Tiger Direct or Amazon ( "Silenx IXAFM20 Silicone Dampening Fan Mounts - 20" ).
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 10,264
2 件のコメント
Can you describe or record the noise for us to hear? I consider my laptop fan extremely noisy...but there's nothing wrong with it, it's just a loud fan! Telling us the age of your computer can help too.
Phillip Takahashi さんによる
Macprofessor さんによる
