broken wire 3.5mm jack how to reconnect it and how to match the cable
hallo everyone
first sorry for my English is bad
my headphone cable is damaged by pulling
can anyone help me to match the cable with jack 3.5mm
I would take off one side of the headset to determine which cable is hooked up with which side. If you have a multimeter you can use continuity or diode mode to check which wire is which.
The same thing you can do with the jack connector.
The connection order for newer devices from the tip of the jack is;
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 117
