Chevy Equinox 2017 ST/ABS lights are on. c0045.06. What can I do?
Both the Stabilitrak and ABS lights are on. I checked with ABS OBD from Innova and got C0045.06. That means left rear ABS sensor. I bought a new one from Adelco and replaced it. with both I tested resistance and spinning the wheel by hand and the results were similar on the multimeter. The lights are still on. Out of frustration I replaced the ABS sensor on the rear RIGHT wheel with the one I removed from the LEFT side. I still get the same error on the Innova OBD. The car is not that used, less than 50k miles. Not sure what to test next. Can anybody give me a hint? Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
