メインコンテンツにスキップ
2014年4月のアップデートによりアップルの13インチMacBook Airはデュアルコアi5またはi7プロセッサーの更新とわずかなバッテリー性能の向上がされました。
MacBook does not boot
Hi!
My Macbook Air 13” does not boot at all. The screen stays black and there is no sign of life at all. When I plug in the charger, it’s saying that it is charging (led goes orange) but the Macbook still won’t boot. Does anyone know what’s going on? I think it’s motherboard related, but before I order a new one, I want to be sure.
Thanks in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Replacing the motherboard fixed the issue. I want to thank everyone here!!
さんによる
コメントを追加
3件の回答
ベストアンサー
It could possibly be your SMC chipset i have encountered this many times, especially in the Mac Minis and in certain macbook Air models
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thanks for your answer! Is this an easy fix? Or am I better off to replace the motherboard?
さんによる
better off replacing the whole machine in my opinion it honestly depends on the amount of time and money you would be willing to invest
さんによる
Alright good to know, thanks :)!
さんによる
Replacing the motherboard fixed it! Thanks!
さんによる
コメントを追加
最も参考になった回答
Here are a few articles from Apple which may be helpful:
If your Mac doesn’t turn on
If your Mac doesn’t start up all the way
How to reset the SMC of your Mac
If you aren’t able to power on your system using these tips, you may have a faulty battery, charger, or DC-In board. To figure out the cause you’ll need to do some troubleshooting or take it in to a repair shop.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
Tested it with different chargers and this didn’t work. All the resets are tried but no sign of life. If the charger is in, it should boot no matter if the battery is faulty, right?
さんによる
@dan0 some devices require a working battery to boot and I wouldn't put it past apple to do this as planned obsolescence
さんによる
That's normally true. In some cases I've seen a bad battery cause power on issues that weren't resolved until a new good battery was installed, but I don't think that's what's going on here.
さんによる
Alright. Well someone is bringing in a known working motherboard. I'll test and see what happens :)
さんによる
If you have a faulty charging circuit and the input diode is faulty, it will stop your laptop from turning on as it detects a reverse current flow towards the charger from the battery. Try to remove the back cover and unplug the battery but nothing else and then plug in the charger and see if you can switch it on.
さんによる
3件以上のコメントを表示
コメントを追加
Firstly, you may make some checks, such as indicator light, cable, power connection, display and so on.
Then, try running Disk Utility to fix Mac issues.
Or reset NVRAM/PRAM to have a try.
Following post can be useful to help you step by step:
https://www.minitool.com/data-recovery/f...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, the indicator light is on (orange). And can’t run disk utility as it won’t turn on at all.
さんによる
コメントを追加
回答を追加する
koppie007 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 19
今までの合計 469
