No Words Showing on screen.
My Tablet will not show any words on screen no matter what website I go to. This is NOT the keyboard im talking about. Its like if I came to this website it wouldn't show any letters at all.
Hi,
Hi,
Try the following and check if either resolves the problem
i). Wipe the cache partition and check if it works OK.
ii). Start the tablet in safe mode and check if it works OK.
If it works OK when in safe mode, then a downloaded app is the cause of the problem. The trick is to find out which one it is. You will need to uninstall each downloaded app, one by one and test the tablet in normal mode between each uninstall to see if it works OK. When it does then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed in the tablet and was not already pre-installed when you got it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 22
