When stopped my Ford Escape smells hot when heater is on
Why does my 2008 Ford Escape smell like it's running hot while my heater is on and I am stopped at a red light…
It might be a coolant leak in the heater hoses or possibly the heater core. Most vehicles have a shut off valve in the the heater lines so when you aren't using the heater coolant is not going through lines enough for you to smell it. I would look for a leak and definitely look at the valve in the heater hose, those tend to leak. Good luck
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 83
Hi @clgarrison66 ,
What's the temperature gauge showing on the instrument panel when the vehicle is stopped at the lights - normal operating temp or hot?
Is the heater blower fan still operating when stopped at the lights?
jayeff さんによる
