Kitchenaid fridge Not cooling in top part
model Krfc704fps03
This was new at a store in July 2019, apparently kitchenaid scrapped it, and we got sold a problem child. What I got with my guages is 11 degrees freezer department, then the lower fridge lowest drawer is around 24 degrees, then 2nd drawer up is 35 degrees, then it jumps to 50 degrees up a drawer, then up to 60 degrees at the very top shelf. THe fresh center thing that goes up the back has no air running though it, even though it has a filter, but when I took that off, I just have foam, no fans etc. I have already checked coils under fridge and fan to them, they are very clean, and fan spins. The inside its like the air isnt moving right. Now with that said, when you open the left door, there is 2 vents, one is blowing, and one is sucking, this goes to the ice ben. I do get very cold air there and with a papertowel can see its sucking air back. Thing is this allows air from bottom I assume to ice part only, no open ports to go back to up fridge itself. What is interesting is the bottom of the fridge is ice cold, while the top is about as warm as the house. The doors are closed, no torn seals. I can not find anything on you tube about how or if there is another fan Im missing or what is going on. Ive already broke a piece on the water filter, trying to get that massive bottom out as I can not find anything anywhere public about how to disaemmble this thing or what is where. I go diagrams under fridge for circuit board that is it. I have downloaded the owners manual, but again, nothing in there for repairs or how to take shelves out etc, or what fan if one is in the back. Advise please.
Update (02/18/2021)
I have found some diagrams on sears and another site, but I cant make heads or tails of what is going where. Nothing here is just outright showing a motor to circulate air inside the top part. I see the condensor and fan for bottom, nothing for top, or the inside fan motor. Nothing to help explain why that bottom piece wont just come out without breaking it either.
https://www.partselect.com/Models/KRFC70...
also
https://www.searspartsdirect.com/model/5...
I found this, but no idea what or where it goes, again this is just like telling someone how to build a rocket engine with no pictures.
https://www.searspartsdirect.com/product...
Update (02/18/2021)
https://www.whirlpool.com/content/dam/gl... I also ran across this, seems a 2nd evap inside fridge in back, really would help to see a real one taken apart of pictures of real time if anyone has. My findings are odd, freezer is 11% but 50% humidity, top is froze bottom, warm at top, but humidity is 10%.
4 件のコメント
Did you ever fix this problem? I just experienced the exact same issue. Thank you
John Daniel Hoho さんによる
I’m having the same issue. How did you correct it? It’s been months w/o a fridge. Please help, as kitchenaid and brandsmart are zero help!!
Jyero さんによる
I have this same issue too! This seems to be defect and should be fixed by kitchen aide! What can we do! Anyone figure out how to fix it?
Julie Smith さんによる
Similar issue commenting here to follow along
kangdaniels さんによる
