メインコンテンツにスキップ
The EliteBook 820 G2 is a 12.5" business-oriented laptop manufactured by HP in 2015.
6回答 すべてを表示
How can change charging port of elitebook 820 g2?
Hi, I have hp elitebook 820 g2 laptop. Its battery doesn't charge with adapter. I tried different ways. I bought new adapter also bought new battery but the problem is still there. When I pluged in adapter then I can use the laptop. Battery is not charged. So please advise me is this charging port issue ? If so can I buy new charging port to fix it ? Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Qasim,
I don’t think that your problem is the charging port if the laptop works from the adapter.
There is most likely something wrong with the charging circuit and/or the charging IC. I attached a couple of schematics from a similar model (840 G2), they don’t tend to vary in huge detail. The concept should be the same.
On the first image U6000 is the IC that talks with the charger on the bi-directional data line SDA_BAT_CHG. I would start looking around those lines to see if there is a damaged component or a short circuit to ground.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Qasim Khan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 737
