problem with the phone unlock slider
hi, my screen has slight damage but has so for some time. the top slider works fine and so do the ipod controls when double tapping the round menu button. the issue is the slider now does not work, so i can see and hear texts and calls but i cant unlock the phone to answer or read them!
is there a way to unlock without using the slider, i dont have a password on the phone so fingers crossed. also is there a repair for this, the screen works partially, seems the problem is only at the bottom, would a restore help? many thanks
この質問は役に立ちましたか?
4 件のコメント
fantastic, i have had the case open which is not a problem, how would i go about repositioning the connector? ie which number connector do i need to reposition or what connector relates to the digitizer? kind regards
evan さんによる
and its an iphone 3gs white. regards
evan さんによる
no.2 is digitiser. Turn phone off first before repairs. I've edited this so that all the links on the right are for your phone. Good luck
pollytintop さんによる
thank you very much, somewhat of a guru and much appreciated and welcomed advice, i shall keep you informed kind sir.
evan さんによる
