メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
iPhone 8 not turning on at all
Hi,
right my iPhone 8 is being a massive pain. What happened was that light through my phone ON THE BLANKET and therefore there was a soft landing and went to something else. After I came back, it would not turn on. I charged it for like a solid 3 hours… nothing. I tried a hard reset… nothing. I went in nothing broken, while closing I managed to rip a screen cable, so I have a new screen now, but it's still not working. The battery was charged. I know that it’s charging because when I put it on a wireless charger it gets warm (like after 1.5 hours, which is normal). I just really don’t know what to do and I don’t know what could have caused it, because it literally landed in a blanket and was working completely fine before that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
10 件のコメント:
does it make a sound when you put it in the charger?
or can you send pictures of the inside
さんによる
The phone itself, no, but my charger makes a pulsing sound, with a different charger it makes no sound... T
さんによる
have you already tried a hard reset while it is in the charger?
さんによる
yup, nothing
さんによる
you should try with a other screen or battery. if it get warm it should be 1 of the 2.
maybe bad quality screen or old battery.
but first try disconnecting the battery and connect it back on(the same battery)
さんによる
5件以上のコメントを表示
コメントを追加
2件の回答
First, you need to press and quickly release the Volume Up button. Then, press and quickly release the Volume Down button. Finally, press and hold the Side button (aka power) until you see the Apple Logo
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes I tried a hard restart, it didn't work. But thanks for your input
さんによる
コメントを追加
If nothing else works then you should try with a new battery or screen(a cheap screen is not always gonna work)
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
But wouldn't it turn on even with a sort of bad battery, I mean the battery was at 54 percent and it was replaced like a year ago so...
さんによる
No if the battery is defect then it doesn’t turn on.
That happens sometimes with third party battery’s
さんによる
コメントを追加
回答を追加する
Maty k さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 59
