メインコンテンツにスキップ
ニンテンドー3DSは任天堂の最新モデルです。より大きいスクリーンに、より長くなったバッテリー寿命と改良されたデザインが特長です。
412回答 すべてを表示
Getting a blank screen when I select system settings.
Just switched my 3ds on for this first time in a few years. Thought I'd check for a software update but when I select “system settings” I get a blank screen. I left it for a while but nothing happens. So I long pressed the power button to turn of and tried again. However the same think happend.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Maybe a corrupt file
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
Anyway of fixing or confirming this is the case?
Also I forgot to say, everything thing else is working fine. I can play games use the camera etc
さんによる
May be try this
The recovery mode (also known as Safe Mode Boot) can be accessed when turning on the Nintendo 3DS while holding A+R+L+Up(DPad). This menu is made to update your Nintendo 3DS through internet, if an update previously failed.
However it is possible to use this menu to delete the nagging update message if your console downloaded an update while in sleep mode. It is believed that this menu simply erases all update data, as it should normally be accessed when the update files are corrupted.
さんによる
That worked. Thank you so much. I had tried the safe mode previously but was using the stick as my up command.
Downloaded update and when it switched back on I could get to the system settings ok. Thanks :-)
さんによる
How do I open the safe mode? It keeps opening me camera even tho I use all the 4 buttons?
さんによる
@Fulcrum You have to turn off your 3DS and press the buttons while the 3DS is booting up.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Mogwai さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 29
今までの合計 983
