My tablet turns the screen off and I have reboot it again but goes
Every time I reboot my tablet it boots up but then an annoying assistant voice says “screen turned off” I didn’t set up an assistant.. It only came on when the problem arose
Hi,
Try the following to see if doing any resolves the problem:
i). Wipe the cache partition and check if it now works OK.
ii). Try starting the tablet in safe mode and check if the problem occurs.
If it works OK, you could check if the voice assistant is turned on and then turn it off and check by starting the tablet in normal mode again
If turning off the voice assistant (or if it is already off) doesn’t stop the problem when starting in normal mode but it doesn’t occur when starting in safe mode, then a downloaded app is the cause of the problem. The trick is to find out which one. You would need to uninstall each downloaded app, one by one and test the tablet in normal mode between each uninstall. When it works OK the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you installed in the tablet and was not already pre-installed when you first got it.
iii). If that doesn’t work you may have to reset the tablet using the tablet’s factory restore feature. (found in Settings)
—————————————-IMPORTANT———————————————
Be aware that a factory restore will erase all your data and downloaded apps. It will restore the tablet to its factory default (or last system updated) condition.
If you decide to try this then backup the tablet to the cloud or a computer using the tablet’s backup feature before performing a factory restore.
Also if the tablet has a Google account you will need to know the account user ID and password so that you can access the tablet once it has been reset. (FRP lock has been enabled).
Once the backup has been completed, reset the tablet by using the tablet’s factory restore feature.
Once this has been completed, check if it now works OK. If it does and you’re satisfied that all is well, (try starting it a few times to be sure) then using the backup performed earlier, restore the tablet to what it was before by using the tablet’s restore feature. Once it has been restored, check that it still works OK. If it does then the reset has resolved the problem.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 60
