Power off after waking from sleep
Wondering if anyone has noticed a similar issue. After letting my 2014 MBP go to sleep overnight and then waking the morning, a few seconds after I log on my MBP will act as if the battery has no charge ( I get the low battery icon with red bar on my display ) and my display goes black. If I connect my charger, the laptop will turn on and runs normally, with the battery indicating it has plenty of charge. The last time this happened, I let it go to sleep with 85% battery showing. When I awoke it the following morning, it showed the above symptoms and once I connected my charger, the battery showed 79% charge. The only thing I had open was a Google Chrome webpage with one tab open. Here are the specs:
MBP 2014 15” with 16GB RAM, running Catalina, all current OS updates applied. Using a genuine Apple 85W charger. coconutBattery shows 90.2% capacity, and only 168 charge cycles.
I have reset the SMC controller several times, as well as performed several NVRAM resets.
I have also “calibrated” the battery by charging to 100%, allowing the MBP to fully discharge the battery until the laptop shut down, leaving it off for 5 hours, then connecting my charger and allowing the battery to charge once again to 100% before turning the MBP back on.
I’ve attached a screenshot of the System Profile window as well as a coconutBattery reading of the battery
I know the battery is 6 years old, but the charge capacity and the number of charge cycles do not indicate a weak battery. Am I due for a battery replacement?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
