メインコンテンツにスキップ
Repair guides and support for the first generation of C/K pickup trucks.
3回答 すべてを表示
締切られた回答
How can I change my alternator belts?
Replaced the alternator for my '65 Chevy C10, now need to put the belts back on but they don't reach if i just pull them. How can i get the belts on with the least skin off my fingers? It is a 327 V8 and the belts rotate only on the alternator, engine and radiator/water pump.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Okay, it would help to know what engine size you have and what accessories you have. i.e. power steering etc. Usually all you have to do is loosen bolt 4 and bolt 7 in the diagram , push the alternator toward the engine block, You then take the belt and place it over the corresponding pulleys. I then usually take a hammer handle or a medium claw bar and gently move the alternator on the bracket away from the block until the belt is tight. Tighten bolt 4 and 7 and recheck the slack in the belt. The accessories and the engine size determine the routing and size of the belt. I hope this makes sense and does help you out.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,087
