メインコンテンツにスキップ
Epson's L220 is ideal for home and home office users looking for good-quality, ultra-low-cost printing, scanning, and copying. Released around 2016.
9回答 すべてを表示
締切られた回答
"Multi-page feed error" keeps popping up with my Epson L405 Printer.
(The don’t have an Epson L405 option) Every time I print a document with multiple pages the multi-page feed error would keep popping up and I have to press the copy button every time to continue printing again. I tried setting the default document size the same as the document’s size and the error still pop-ups.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
Sorry for my bad English :)
さんによる
Does the "Multi-page feed error" message appear on your computer screen or on the printer's display panel?
さんによる
It appears on the computer screen
さんによる
コメントを追加
3件の回答
If the error appears in your computer and not on the printer itself, the issue may be the printer's driver. Try uninstalling the current printer driver and then installing one from Epson's Website at the link below:
https://www.epson.com.sg/Ink-Tank-Printe...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I uninstalled and installed the driver again, it didn't work D;
さんによる
It could be that many pages were fed to the printer at once. Try removing all the printer paper from the tray, putting it it back, and then pressing the color button on the printer.
さんによる
コメントを追加
Even I had the problem with my L485. The only solution is to keep less number of paper in the feeder and check if the paper's corners are not bent
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have same problem with epson l3150 ,everything else work fine but in double side printing it gives error -multi feed error but there is no paper stuck ,if i print odd/even print then it works fine
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 1,384
