~Lenovo ideapad L340-151rh gaming~ my laptop will not turn on.
the power light on the side stays orange while the light on the power button blinks blue. I re-adjusted the battery but nothing. Please help me out someone!
Have you tried unplugging the power, removing the battery, pressing and holding the power button for 30 seconds?
Sometimes a blinking power button means that it's charging the battery. Sometimes blinking lights might even indicate a hardware failure (for instance, a failed battery, or damaged motherboard, or some other issue).
You would have to reference your laptop's user manual for more information on how to interpret these lights.
You can just do some troubleshoot to see if any of these works for you.
このアンサーは役に立ちましたか?
Your laptop may be in sleep mode and needs to “woken up”.
Lenovo has some more suggestions in this short video:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 15
過去 30 日: 38
今までの合計 2,043
I have the same problem. My charger has a light on it and when its not plugged to the computer its on, but when i plug the charger in the light turns on and off.
Edik prishko さんによる
