Why are some of the buttons not working on my calculator?
Ill push buttons on my calcualator and they wont work. I’ve tried pressing the reset button on the back, and I can even do 2nd 714 because my 7 button doeasnt work. What do I do?
This sounds a lot like a hardware problem with a circuit that’s broken for that key column. Unfortunately, I don’t know how to help you fix the issue from the hardware side and from the information I gathered I don’t think you’ll be able to fix any hardware issues before your ACT. However, MateoConLechuga may have away to fix it through software
Since your calculator may not be reliable, I think your best bet is to see if your ACT proctor has a spare calculator or if some student brought along a spare. If there’s no spares, then just know that most commands and operations you need are available in the catalogue (which you access by pressing [2nd]>[0]).
このアンサーは役に立ちましたか?
Hello, Asm84CEPrgm is crossed in bleu. Can you help me ?
@albertsiebe you got suckered by TI. There's more info about it and a possible fix here: https://www.youtube.com/watch?v=dGq-nsNO...
過去 24時間: 1
過去 7 日: 7
過去 30 日: 26
今までの合計 765
