Replacement Display without faceid
I am about to buy a replacement display to determine whether or not the display is causing my device to appear dead. However, in order to be able to return the display if that´s not the issue I am trying to figure out if the display would work without attaching faceid and just plugging in the two display flex cables. Thanks.
この質問は役に立ちましたか?
1件のコメント
Keep in mind that you disconnect battery cable first then you can disconnect screen flex etc. , after you taken of metal bracket.
Leslie Leslie さんによる
