メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
4 year old water damage but MBP still works, worth it to fix?
Hi,
A few years ago a friend gifted me her 2015 MBP which one of her kids had spilled juice on. She’d been advised that she should get a new laptop, which she did, but the only thing wrong with the water damaged one was that the keyboard and trackpad were dead, hence giving it to me. I’ve been using it ever since with no issues at all, it runs brilliantly and has never frozen, faltered, or acted weird in any way… I’ve used it to edit videos and it’s absolutely fine, fans work, battery’s great, etc. But using an external mouse and keyboard is getting really old. I was thinking to try and replace the logic board, but the more I read, the more I think it could be worth having a look inside and giving it a clean if the corrosion is limited to the keyboard and trackpad … or replacing those parts if necessary.
Do you think that could be the case? Does it sound like the damage might be limited to the trackpad and keyboard? Is it worth it to even try since it’s working well otherwise? Sorry I can’t attach pictures, I’m waiting for my screwdrivers to arrive and getting antsy! :D
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Just in case somebody comes across this and is wondering: I opened it up and luckily the logic board looks completely unaffected, liquid indicators are white and no signs of corrosion on the top anyway. The trackpad board is completely corroded though and cleaning with alcohol didn't work. Now to replace the battery and trackpad! Yay?
さんによる
コメントを追加
1 件の回答
Yeah I personally would go for it! The specs on the old models are fairly decent for even modern applications. If this answers you question please accept my solution.
Thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi, thanks for replying, I just wanted to comment because I'm so pleased with myself, I managed to replace the battery and trackpad for £100 and it works perfectly now! I'm typing this on the actual keyboard! So stoked. Cheers.
さんによる
コメントを追加
回答を追加する
Georgina Hardcastle さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 29
