メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
679回答 すべてを表示
iPhone 7, 7+, 8 and 8+ Home Button
Myself and other technicians are having issues where on the above models, when we move the home button from the broken screen to another one, it temporarily stops working but the fingerprint reader works fine, it just doesn’t work as a button. We have to reset to factory settings and set it back up or turn it off and on around 5-10 times for the button function to start working again. Any ideas?
So just to sum up, the buttons aren’t broken the button function doesn’t work until the phone’s been reset a couple of times but touch ID still works as normal.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
How often does this occur? Meaning does it happen every time you repair those models or does it happen randomly? I’m thinking you might have a batch of defective parts or it could be that you’re being to rough when removing the buttons. Where are you ordering parts from?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I can’t be quite sure where the parts are coming from as the accounts team order them in bulk. It’s mainly happening on the 8 and 8 plus but occasionally will happen in the 7 series. Hard resets don’t solve the problem but if we reset the devices a couple of times, the button function comes back to life.... it’s very odd
さんによる
@coopzzz360 like I mentioned above, it could be a batch of defective parts. I used to work for one of the big chains in cellphone repair and we constantly had issues with our parts supplier, despite them being more expensive that the really good suppliers. I would suggest trying screens from a different supplier if possible.
さんによる
コメントを追加
回答を追加する
Luke さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 33
