メインコンテンツにスキップ
2017年6月発売。このiPad Pro 10.5インチモデルは2016年に発売されたiPad Pro 9.7インチモデルのアップグレード版です。
145回答 すべてを表示
My Ipad Pro 2017 bent. I bent it back and now it won't charge.
My Ipad Pro 2017 got slightly bent on the right edge (looking at the screen) while it was in a case. I noticed when the screen looked like it was being pushed on in that area, the bend wasn’t noticeable until i looked at it on the side.
I bent it back gently by hand until the screen pressure spot was gone, and now the Ipad won’t charge. The battery is discharging as usual, just nothing happens when I plug it in.
Is there some specific connection that could have been broken or disconnected by a slight bend forward and back in the center of the right edge?
I’ve tried different cables, different AC adapters, different wall plugs, and cleaned the port. This happened right after I bent it back so I’m pretty sure that’s the issue.
Here are pictures of the bend:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
you might get away with having the charge port replaced but looking at where the bend is lots could have happened, a chip could have lifted. A board-level repair shop might be able to deal with it. (ipadrehab)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Dublin Nichols さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 14
今までの合計 233
