メインコンテンツにスキップ
The Bose SoundTouch 10 is a compact and portable speaker measuring just over 8 inches tall and released in late 2015. It is Wi-Fi and Bluetooth-enabled, and it comes with 2 color options - black and white.
8回答 すべてを表示
SoundTouch 10 not powering on, replaced port but same.
As titled, I have dead SoundTouch 10. I replaced port but still doesn’t power on. One thing I notice is the big fat cap that suppose to hold charge is hissing. Does that mean cap is bad? or can it boot without the cap if I remove that capacitor?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi,
“Does that mean cap is bad? or can it boot without the cap if I remove that capacitor? “
YES and then NO.
It is faulty and most probably it will not power on with it missing.
If you can hear a hissing sound coming from the capacitor, it is venting.
Be safety aware:
The gas expelled from a venting capacitor is more than 100°C. Never expose hands or face to a venting capacitor. If your eyes are exposed to the gas, flush with water immediately. If the vapor is inhaled, gargle with water. Electrolyte leakage may occur after a capacitor vents. If the electrolyte comes in contact with the skin, wash with soap and water
Disconnect the power from the board and replace the capacitor and then re-evaluate the problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
iFIX smartphone さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 33
今までの合計 778
