メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年10月発売のGoogleのPixel 4 XLスマートフォンのリペアガイドと解体情報です。
Front camera and Face ID stopped working after disassembly
Hi friends,
I teardown my pixel 4XL to replace rear camera. But when I assembled again, my front camera and faceid can not work. Face enrollmend didnt work , front camera black screen when flipping from.rear camera to front camera. I am quite sure I teardown carefully.
Really appreciated your help.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
I too am having the same problem I even replaced the front camera and sensor assembly. The camera app doesn't work for front camera at all. It dose however show a B&W imagine on other apps but it isn't using the camera but the sensor to the left of it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
were you able to find a solution to this? i am having the same problem. already replaced it and yet nothing on camera app. i also have the BW on other apps.
さんによる
コメントを追加
Well possible reason maybe that the clip connector is not properly connect to the main board, which will cause the face id not to function as well and also result to the black screen when camera flips from rear to front.
Or the flex connector connected to the main board is cut now.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tan Vo Huu さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 857
