Is there an extra slot for SSD?
For ASUs Vivo flip tp501uq
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Looking at the motherboard in a SSD replacement video for the laptop there doesn’t appear to be any extra SSD connection types there i.e. M.2 or sata.
One option that you may want to think about if you want to have extra storage in the laptop, is to insert the largest capacity SD card that you want, into the card reader and leave it there permanently and configure it as a storage drive.
It is unobtrusive and out of the way and also it is nearly as fast as a SSD as well. One downside is if you often need use the card reader for other purposes i.e. copying images from a camera’s card etc.
このアンサーは役に立ちましたか?
Muy buenas, si se puede poner un SSD M.2, en la parte trasera de la laca base (justamente como para ampliar la RAM, al lado de esta) hay un slot m2, si mal no recuerdo era para los de "80"mm, no me deja adjuntar imagen, le dejo un link donde se aprecia perfectamente, un saludo.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 312
1件のコメント
https://www.empowerlaptop.com/wp-content...
Mikel Fernandez さんによる
