メインコンテンツにスキップ
A film and slide scanner from Nikon identifiable by the model number LS-40 ED.
5回答 すべてを表示
Anyone know how to open this up for cleaning?
I have a Coolscan IV slide/negative scanner and would like to clean it. There is gobs of dust on the element. Can't really just get in there with an air can.
There are screws holding the steel shrouding on the back, but I cannot seem to get the plastic front plate off. Not sure if it should pop off, or if there are other connectors.
I would appreciate help here.
Many thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
If you check on the link I sent you, it says "To get the front faceplate off, use a flat screwdriver to gently pry the tab away from the chassis"
さんによる
コメントを追加
1 件の回答
選択されたソリューション
jmmx, check on here it should show you how to do it....Good Luck
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
This is great. I guess I will give it a try. I received a quote of $40-90. I am sure it would wind up closer to the high end.
Many thanks!
さんによる
Wow that seems steep. Looks like you could do most of it by yourself. Just take your time and keep it clean ;-) Save some money....
さんによる
コメントを追加
回答を追加する
jmmx さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 1,800
