I need to bet a replacement adapter for my iPhone thomas kinkade
I need to bet a replacement adapter for my iPhone thomas kinkade train Christmas tree
Hi,
The Christmas tree can operate on 3 x AAA batteries which means that it operates at 4.5V DC.
Try using an adjustable, multi voltage power adapter (example only) where you can select the 4.5V DC output and it also comes with a range of plug adapter sizes so that you can get the correct one to fit the connection in the device as I don’t know what the correct size may be.
このアンサーは役に立ちましたか?
If I had to guess about the connector size, I would guess 5.5 mm x 2.5 mm or 5.5 mm x 2.1 mm . Very popular sizes on the electronics I have.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 571
Your question makes no sense.
atexit8 さんによる
@atexit8
I think it is just a typing error and that the OP wants a new power adapter for the device i.e they most probably typed "bet" in lieu of "get".
Although I agree that the reference to "iPhone" doesn't fit with the rest of the question ;-)
jayeff さんによる
@jayeff Thanks. I guessed that 'bet' may be 'get'.
But I couldn't figure out what iPhone thomas kinkade was.
atexit8 さんによる
