メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
Click wheel not playing/pausing
The click wheel on iPod Classic (Late 2009) doesn't work for playing or pausing. To get it to play I have to press it 20-30 times just below the play/pause symbols. Once it's playing I just remove the headphone jack to pause playback. All other functions work properly forward/back, Menu, volume control, and the center button. Unit charges normally, and is recognized by iTunes/Windows. Is it just the click wheel that needs replacing?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
place your iPod in diagnostic mode "Menu + Center >Previous + Center" In the diagnostic mode it allows you to test your click wheel. You can check on it. At this point I would think that if everything else works the way it is supposed to, just change the click wheel. Not a terrible job, bit of a bear to open the iPod, and cost effective. Once you change it re-evalaute and see what you got. Make sure that when you do change it, take a look at the micro switches on the logic board. They have to correspond with the click wheel.
iPod Classicのクリックホイールの交換
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Thanks for your reply. Looking at slide 34 in the instructions I see the micro switches you are talking about. Now I'm wondering if the micro switch that corresponds with the play/pause button is bad. Can I test that somehow?
さんによる
You can check the switch through the diagnostics as well, It does give you the option. You could also disassemble the iPod and test the switch with a multimeter.
さんによる
The keypad button test fails on the Pause/Play Key. Once I figure out how to get out of this testing I will try the Wheel test.
さんによる
okay sounds good. let us know
さんによる
コメントを追加
回答を追加する
mike marcott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 11,481
