メインコンテンツにスキップ
The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108回答 すべてを表示
Powers on but no picture
Hello! I am hoping to find someone who could help me figure out why my tablet screen is not working. The tablet itself turns on but it does not show anything on the actual screen, it is just black. So far, I have had the screen and the circuit board to it replaced as well as getting a techs opinion on it. They told me that I might as well buy another and that there isn't anything that can be done. I have already bought another one but I'd like to know if there is anything I can do to salvage the one that is messed up.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @davesr ,
Does it also do this with the charger connected?
It seems very strange that replacing the screen and the motherboard did not solve the problem as there is not much else in there that affects the screen unless you used the original LCD ribbon cable that came with the tablet.
With the tablet on, try shining a torch at an angle close to the screen and check if you can detect any images at all on the screen. They will be very faint if they are there so trying this in a darkened room may help.
If there are images then there is a backlight problem but as you have replaced both the motherboard (which controls the backlight power) and the LCD screen then all I can think is that it may be the LCD cable (if it was the same one) or that one of the replacement parts was faulty or the wrong one or perhaps the battery is faulty and it can’t supply enough power to turn on the screen and run the tablet.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dave Rouse Sr さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 53
