Why is there no video?
So my GameCube has no video, but it has sound. Further inspection shows that only the red input is working and not the white and yellow.
i tried switching cables and that didn’t work.
thanks in advanced
この質問は役に立ちましたか?
thanks in advanced
この質問は役に立ちましたか?
Hi,
Here’s a video that may be of some help with locating the problem.
Also here’s the ifixit Nintendo GameCube guides as well which may help with getting access to the component parts
このアンサーは役に立ちましたか?
How about check to see if the video connector has a bended pins or damaged pins?
このアンサーは役に立ちましたか?
There at no bent or damaged pins
過去 24時間: 3
過去 7 日: 33
過去 30 日: 141
今までの合計 10,001
2 件のコメント
Hi,
Have you proved that the the AV input (yellow - video + red & white - left and right audio) on the device (is it a TV?) that the game cube is connected to is working OK, you didn't say? You only said that you changed cables.
Try connecting another device that has an AV output to the device, e.g. a dvd player and check that there is video and audio when using it to determine whether the problem is in the game cube or not.
jayeff さんによる
Hi! So I tested the same cables and TV with another GameCube I have, and it works fine.
Thanks!
David Lank さんによる
