メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
締切られた回答
Replacement battery wont take charge.
I recently replaced my 3GS battery with the iFixit replacement. The install went smoothly and the instructions were great. After reassembly the phone it started right up and showed 100% battery life.
I continued to use the phone for a full day and noticed that the battery percentage never changed from 100%. By the end of the day, unsure of how much life was actually left in the battery, I pluged the phone into the wall to charge over night.
The next morning I removed the phone from the charger and used it for about 10-15 minutes and it died.
It displayed this screen when I tried to turn it back on:
http://km.support.apple.com/library/APPL...
I attempted to plug it back in to charge again seeing as it was telling me the battery was dead, but no matter how long I left it plugged in it would not take a charge.
I have since removed the replacement battery and re-installed the original battery and the phone now works as normal.
Any insight as to what this may be? I checked the screws under the do not remove sticker and they were tight.
edit: software is IOS5
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
My suggestion would be to contact ifixit sales for the battery. If your phone charges the old one without problems but does not charge the new one, try to exchange it. There are some issues with batteries for the 3GS with a bad circuit...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I will contact them about it. Thank you.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 891
