Speed only works on highest setting on the dial
Hi my Kenwood mixer will only work at the fasted setting on the dial
Update (12/18/2020)
- On the fastest setting on the dial
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@freddifrog this is most likely caused by a failed spark suppression capacitor for the governor. IF it fails your mixer will only work at full speed. Check for it under the cover on the bottom of the motor. You’d be looking for a small, round, aluminum can looking part. Post some images of what you find so we can assist you further with that.
Here is Untitled the service manual to help you with your disassembly etc.
このアンサーは役に立ちましたか?
there are two aluminum can looking parts but how do I know which one works and how can I replace it and where can I get the part?
There's sure to be a label on it. Post a photo here, we will help. Replace both, they're cheap. You can usually get them through an mail order company for electronics.
I had the problem on kcc9060. I changed the dial element (so the triac) and i solved the problem.
このアンサーは役に立ちましたか?
The problem returned its not the dial maybe the motore rotation sensor
過去 24時間: 0
過去 7 日: 2
過去 30 日: 31
今までの合計 1,059
9 件のコメント
Can't find an option to add a photo
P Greenwood さんによる
@freddifrog here is the guide for it. iFixitでの質問に画像を追加する方法 You'll have to edit your QUESTION and add those images to it.
oldturkey03 さんによる
Thanks. Just having a look.at it now
P Greenwood さんによる
Apparently I need a part
P Greenwood さんによる
I need a part BTA208-600B
P Greenwood さんによる
4件以上のコメントを表示
