Is there a way to fix this damanged ribbon cable port
I was having issues with the right joycon rail, and took it to a mall kiosk… They returned it saying that they couldn’t fix it… I opened the Switch and this is what I saw ;-;
Has it been opened before you got it? Is the joy con working on that side? To replace the connector, it would need to go to someone who can micro solder. You may be able to get away with putting a piece of thin plastic, or paper in between the connector and flex cable to help make a better connection.
このアンサーは役に立ちましたか?
At the time of writing (11th of jan) here would be a replacement connector: Ribbon cable connector for Switch Joy-Con SL SR rail
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 5
過去 30 日: 13
今までの合計 803
