メインコンテンツにスキップ
2016年2月に発売された「Asus Chromebook C202」は、学生を意識して作られた堅牢なデバイスです。 ちょっとした食べこぼしや落下にも対応できる小型ノートパソコンです。
17回答 すべてを表示
How to remove management from school chromebook
I want to use my asus chromebook C202SC for stuff like youtube and stuff but i found out its managed by an extension called “GoGuardian” later on and i can’t uninstall it so i need to unenroll.I have tried ESC+REFRESH+POWER thingy but it is still managed so can somebody help me? I have to do this because at the end of my school i will give it to my younger brother so he can use it for gaming but all websites are blocked.Please help? If so then thanks!
-Nik
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 109
19 件のコメント
This works up to 2022. Press Esc, Refresh, and Power; Next press Ctrl-d, next press enter than press enter again and done.
さんによる
how to do it in 2023 please!!!
さんによる
ctrl refresh power then ctrl d then enter or space
さんによる
its not working
さんによる
yea it aint. it just rebooted the device, the administration is still there
さんによる
14件以上のコメントを表示
コメントを追加
11件の回答
ベストアンサー
Nikolas Castillo you cannot the enrollment without access to the admin console under which your Chromebook was enrolled. You cannot enter developer mode without your administrators permission. That means you will need the credentials for those administrators otherwise it’s a no go. Of course you can check on here My chromebook has an admin on it, how do I remove it? for more info
このアンサーは役に立ちましたか?
スコア 24
8 件のコメント:
Can I do something with the memory chip to remove all admin data?
さんによる
Nikolas Castillo sorry but that is a no as well. There is nothing you can do without the admin login.
さんによる
its still managed and i am on summer break
さんによる
maybye i can do what tryhard.tech said i could ask them
さんによる
Once you leave your school or workplace, they will remove the administrator from the chormebook
さんによる
3件以上のコメントを表示
コメントを追加
Sorry to break this to you but it’s pretty much impossible the chromebook is most likely managed by you’re school, and there’s only 2 solutions. 1:Contact you’re districts IT department and ask them to untie the enrollment. 2: or if you’re really tech savvy then you can change the device’s serial number breaking the admin's control which you probably cannot accomplish.
このアンサーは役に立ちましたか?
スコア 6
7 件のコメント:
whats a cereal number?
さんによる
JK i know what a serial number is.
さんによる
all i know is you order replacements on it
さんによる
but i had no clue you could change it
さんによる
@Nikolas Castillo It's possible if you know how to soldier well.
さんによる
2件以上のコメントを表示
コメントを追加
First, powerwash the chromebook. Sign into the internet and when you get to the screen where it says “Getting device configuration” click the notification center in the bottom right corner and get ready to turn off the wi-fi. When the screen turns to “Enrolling device” Turn off the internet. It will say “Enrollment Failed” Then click the button “Enroll manually” This should pull up a screen saying “no internet”. Turn the internet back on and click the back button. Eventually, in the bottom left corner, buttons will start to appear. First, Apps (If your district has apps). Second, Browse as Guest. When Browse as guest appears, go back and forth clicking the back button and the Browse as Guest button. Eventually, the chromebook should crash when you click browse as guest. Finally, press esc + refresh + power and it will take you to a screen where it says “Chrome OS is missing or Damaged” Press Ctrl + Search (Ctrl +Shift on older models) and then press enter to go into developer mode. Then, the screen will say “OS Verification is off. Press space to enable” Press space to enable then press enter. Finally, the chromebook will reboot and the enrollment should go away. If it doesnt work, then try it again.
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
Does this work?
さんによる
I have already downloaded my entire Chromebook in caseof emergency.
さんによる
Where's the back button?
さんによる
コメントを追加
Try making a Ubuntu USB stick with another PC and make it bootable with something like Rufus. After that, plug it in to the Asus and shut the chrome book down. Now, press POWER and start pressing F12 right away.
It should boot to the Ubuntu boot loader.
If this is a Chromebook you bought: Install Ubuntu and erase the HDD
If this is a school issued device: Use the Try Ubuntu option.
If they somehow locked the boot Menu, I don’t know what else you can do other than replace the OS
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
ESC+REFRESH+POWER worked for me i just did it but at school and they dont give out the wifi so i dont know if it will work
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
First of all, it's not a good idea to use the school computer, but you're looking for a way to unlock it, not the answer, right? Let me tell you. This is a fairly easy method, so you can do it in no time. First, press the three dots on the top left. Then, press "More Tools" and press "Task Manager" from among them, and an extended function will appear in the middle of the screen. After pressing "End Process" below, you are now free.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
First, sign out of your chromebook. Then, Press Ctrl + Alt + Shift + R At the same time then press Powerwash>Restart Then press the blue button, Then connect to a network and decline all privacy policy.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
to unblock go to sigh out and click ctrl shift alt r if its blocked still click esc restart power it still we be manegd.but click ctrl alt shift r then gust mode
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
  1. Sign out of, restart, or power off/on your Chromebook.
  2. Press and hold Ctrl + Alt + Shift + r all at once after the Chromebook has restarted.
  3. Select Restart.
  4. In the box that appears, select Powerwash. ...
  5. Select Let's go.
  6. Connect to the wireless network: ...
  7. Accept the Google terms of service.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That doesn’t remove management.
さんによる
コメントを追加
to remove GoGuardian sign out of your account press ctrl, alt, shift, and r at the same time press restart, and then press powerwash and follow the instructions or you could open the back of computer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
May be late, but a kid at my school found a way a while back. In case all other methods fail, you can buy a new motherboard and replace it through the back. Make sure to get the right model. In case you have to return your Chromebook around the end of the school year (if you don't own it). When times come, switch out the motherboards again and pretend like nothing ever happened. It worked for him multiple times and it will most likely work for you too. May be pricey, but there will be little to no permanent damage.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
how to get right model?
さんによる
@haisy The model number will be printed on a label on the bottom of the computer. If we're still talking about this particular Chromebook, then you can see the label on the first step of the palm rest replacement guide here.
Asus Chromebook C202SA-YS02 パームレストの交換
In most cases this will be all you need, but if you open it up and check the motherboard, there may be a separate model number just for the motherboard; if that's the case it would be best to use the motherboard number since that will always give you an exact match.
さんによる
コメントを追加
回答を追加する
Nikolas Castillo さん、ありがとうございました!
統計データ:
過去 24時間: 113
過去 7 日: 605
過去 30 日: 2,593
今までの合計 70,085
