メインコンテンツにスキップ
The Dell Latitude E6500 laptop PC was released in August 2008. The Latitude has a 15.4 inch screen with a 500 GB hard drive
20回答 すべてを表示
How do I get this working
my dell isn’t starting up i think it is the battery that doesn’t make it start
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi @xxthenottakenxx ,
Does it start with the charger connected to it, you didn't say?
What lights are showing when the charger is connected or when you try to start it and are they flashing or steady?
さんによる
コメントを追加
1 件の回答
If you doubt it’s the battery interfered the computer's startup process. Try removing the battery to run the laptop from just the AC power. If it works, you may have a defective battery that needs replacing.
If nothing fixed the problem, this indicates that the problem may be on other components of the laptop, at least you can do some basic troublshooting.
https://www.minitool.com/backup-tips/del...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
The not taken さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 10
今までの合計 135
