メインコンテンツにスキップ
A laptop by Lenovo that can function as a tablet.
Is replacing the power adapter jack possible?
Is replacing the power adapter jack possible? Would that mean unsoldering it from the mainboard, finding a replacement jack, and then soldering the jack into the mainboard? That sounds pretty adventurous.
Yoga 720-13IKB (Type 81C3) Laptop (ideapad) - Type 81C3
Model Name: 81C3
Mfg Date: 17/10/09
MTM: 81C3000LUS
Page 50, 51 of Hardware Maintenance Manual shows the power adapter jack.
For Lenovo YOGA 720-13IKB, the AC power adapter jack is compatible with Type-C USB 3.0 devices.
Service Manual
https://download.lenovo.com/consumer/mob...
User Guide
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Loren Watts yes, that is what needs to be done. Not as bad as is may sound, for as long as either you know how to solder, or you know somebody that does. Disassemble the laptop using your service manual or videos like this After that desolder the old connector. Clean the solder pads and replace the connector with some like this This one is costly and you may find a less expensive jack.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you @oldturkey03 for the research and confirmation. I'm okay with the teardown, but I'd probably get help for the soldering part of the task. Thank you for helping me.
さんによる
コメントを追加
回答を追加する
Loren Watts さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 373
