Phone won't detect WIFI but Bluetooth work
My phone had water damage (Wifi and bluetooth not worked ) . After had it fix, only Bluetooth worked. My phone could not detect WiFi at all. Is this hardware or software problem?
Hi @khatz ,
If it was professionally repaired take it back and tell them that it is not working properly after they fixed it. They should have tested all the main functions of the phone before handing it back to you.
There are two antennas in the phone so maybe it is a problem with them although Bluetooth and WiFi share the same antennas and also the same IC chip on the board so it is unusual that one works while the other doesn’t unless it is damage that they didn’t fix.
Here’s the ifixit Samsung Galaxy A50 Battery Replacement guide. It is only linked to let you see the blue and white antenna wires in the phone. They can be seen in the image in Step.19 .
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 212
