Pine Pitch on Down Jacket!
Do you have suggestions on how to clean or remove the pine pitch ?
My beautiful coat has many spots and I haven’t found anything to remove the stains.
Thanks much !
この質問は役に立ちましたか?
Thanks much !
この質問は役に立ちましたか?
I’d try Goo Gone, the yellow orange stuff. It works on paper/magazines it should be ok on fabric. It could leave an oil spot which might evaporate over time or probably come out in the wash. WD-40 another possibility.
このアンサーは役に立ちましたか?
Hi @bonstelle ,
Have you tried “rubbing alcohol” to see if this removes the pine sap stains, you didn’t say?
Before trying it on the stains, try swabbing a small area with a Q-Tip moistened with the rubbing alcohol, in a place where it won’t be noticed, just in case it affects the dye of the material.
このアンサーは役に立ちましたか?
thanks jayeff .. another great suggestion .. will try as well.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 130
