メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年3月に発表・発売された、iPad Pro 12.9インチ第4世代の修理と解体情報。モデル番号はA2229。
For what exactly do you need a laminating machine?
Hi, recently I disovered screen-only repairs. Specifically on the channel of Cambo fixing. Because I have seen him laminating screens, I wanted to ask what exactly the purpose of laminating is.
I just can not get behind the purpose of laminating and I would like to know if it is necessary, as I just know that these laminating machines are very expensive.
I’ve done a few repairs of Apple watches, iPhones and iPads but all of them had broken LCDs or the Digitizer was not glued to the LCD so they were fairly easy to change.
Thanks for your replies!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The glass and the display panel are actually completely glued to each other, eliminating air gap so you touch what you see, reduces reflection and scattering, also it makes the display stronger and less likely to break.
If it does break however, you end up with a glued mess that needs professional skills and tools to separate and reassemble without ruining it for good.
If you don’t clean up the residual glue and use a laminating machine to glue everything back together, the screen will look like someone just puked on it.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
So just to make everything clear. If you want to combine a LCD Panel and the Glass on it, you glue them together, put them in the lamination machine to strengthen the glue . Then you put the phone in the “de-bubble” zero pressure chamber. That should be it, right?
さんによる
コメントを追加
I’ve used laminated screen tablet, There is no gap between the glass and the screen. It looks better without the gap. Also prevents dust from getting in there.
Check out this: https://pctechtest.com/laminated-vs-non-... , very detailed explanation.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nicolas さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 16
今までの合計 1,211
