How thick are the thermal pads on memory ICs?
Would like to know so I know what thickness pads to order.
Is there any reason you would want to replace them? I know there was a video showing how hot the ram gets but we haven’t seen many (if any) failures from this so far.
このアンサーは役に立ちましたか?
I would assume their reason would be the same as mine: General maintenance, and life extention of their console. Better not to wait until it does cause a problem before maintaining it.
Between 0.7-1.5mm.
I'd opt for trying which ever is the thickest in that range that can be fitted perfectly.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 25
今までの合計 841
