ABS, traction control issue
Hello, a month ago my ABS and traction control and ESC light came on. It went off after a few days. Now its back on. Went off for a day, went back off for a day then went back off. What is the issue?
if its intermittent have you checked your battery, if the voltage gets low a lot of cars will shut these systems off the keep the engine running. other than that I would look towards faults with electrical parts of the braking system as they’ll be wired into each other, start with simple things like brake light fuses are firmly pressed in and secure.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 10
過去 30 日: 21
今までの合計 624
