メインコンテンツにスキップ
2015年3月に発表され、同年4月に発売されたGalaxy S6はGalaxyラインの中で最高のデバイスです。端にカーブが施されたスクリーンはGalaxy S6 Edgeです。
487回答 すべてを表示
Galaxy S6 unresponsive after dropping
After dropping my phone from waist height it won’t turn on and there is a slow flashing blue light. I’ve tried all rebooting methods but still nothing. Removed and replaced the battery but the same thing happens after pressing the power button. Computer does not recognize it and calls go straight to voicemail.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
This can be caused by multiple components. It might be the case that you just have a malfunctioning display. In order to boot up the SIM card the phone needs to unlock it (by typing in the sim code). Also in order for a computer to recognise it the phone needs to give permissions, also by unlocking the phone. If the problem aint the LCD display, it is highly likely to be a problem with the logic board, which I wouldn’t recommend bringing it for to a repair store. The costs of repairing the logic board wil likely be more then the value of a new S6.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Just tried to disconnect and reconnect the battery, display and motherboard again. When trying to reboot the screen flashed briefly. After multiple reboot attempts the back and recent app keys would flash for a second but the screen never flashed again. The blue light only came back when using the volume down + power button but not any of the other reboot methods. Would that be more of an indicator of a broken display, or logic board?
さんによる
コメントを追加
回答を追加する
Brandee さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 30
