メインコンテンツにスキップ
AppleのPad 6のWi-Fiのみのモデルは2018年3月に発売されました。32GBと128GBの容量オプションがあります。9.7インチRetina ディスプレイと64ビットA10 fusionチップを搭載しています。
150回答 すべてを表示
Unresponsive band in screen after digitizer replacement
I just performed a digitizer swap on a very badly cracked iPad 6th gen. After reassembling everything, I crossed my fingers and cheered as it turned on, then again after I found the touch screen was responsive. However, upon trying to enter my passcode, I realized that there is a horizontal band across the screen that does not recognize any touch, infuriatingly in the same place as the top row of numbers. How do I fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
hello Joel,
unfortunately, it is often talked about. There are many reasons why touch after replacement does not work partially. Most often it is a badly positioned connector in the proper port. The connection is mechanical and sometimes fails. Clean them and make sure all copper pins are in place. The second common reason is that the digitizer was damaged at the factory or during assembly. Of the 100 bought, over 15% are often damaged, while damage during assembly occurs on the edges of the signal tapes, along the main paths - at the edge of the contact with the housing. A abrasion is enough to turn off the entire section. Good luck.
  • regards,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joel O. さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 281
