メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年10月13日に発売。A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 プロセッサ。
Ghosting of screen images
I have this problem with a 2015 iMac with 21.5" retina display, but it only happens with certain streaming videos, nothing else.
So 90% of the time I have not problem, but if I stream a video that's embedded in a web page, occasionally it will instantly start retaining/ghosting the image.
It then takes a while to dissipate, most effectively by filling the screen with a white page. Turning the computer off does not fix the problem.
It does not happen when I edit video with Adobe Premiere, or use Photoshop, or any other program. Just certain streaming videos, and not all of them! Very frustrating.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
There are 2 issues I can see causing this.
If you are using a program to watch the videos that has a bug which causes this or
Your graphics card is going bad.
Try troubleshooting by watching the videos with some other programs. If it seems pretty universal, then I would say there is definitely a hardware level issue. Another thing you could try is using another monitor. If that monitor does not have the same ghosting affect, then it is an issue with the display. If it does, then its an issue with the GPU. However, it could still be a GPU issue even if the image does not ghost on the monitor. Might be time to bring it in to the shop or look into replacing parts!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Check your Monitor's refresh rate. Some streaming service might turn it down. When in these services, try going to the right to see if there is an interactive tab for settings and adjust the refresh rate higher. This can cause drop out of video because services intentionaly set this lower to fix buffering issues and down load size and time. hope this helps,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rebecca Abbott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 48
今までの合計 457
