メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2273回答 すべてを表示
Battery issues - Health stuck at 100%
I got my Iphone 7’s battery replaced about 7mo ago, as I cracked the screen, and the guy said it was only really worth his time to do both, plus I needed it anyways (Bought this phone refurbed) This was all before I had ever taken apart a phone, now I have. I feel like I should replace it, as the battery health is stuck at 100%, 3utools doesnt give me a health or a manufacturer either. I wonder if this is a bad battery, and if I should replace. The battery life has been not great, I now have to charge it 2x a day, after the IOS 14 update. Is this battery bad, and should I replace it? Would this fix the many crashes and freezes I have while using this phone? I suspect it may, but IDK. Thanks for your help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
If 3uTools doesn’t display the battery info there are usually 4 possible causes.
1.       Faulty battery.
2.       Damaged connector.
3.       Nudged component near the battery connector.
4.       Faulty charging IC usually Tigris.
Batteries are not that expensive and most times fix the issue.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Dylan Devries さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 1,401
