メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1288/ 8, 16もしくは32 GB容量
Battery replacement problem checking voltage
I bought a replacement battery from Ebay. It reads 3.8 volts across the 2 outer terminals on the ribbon cable that connects to the main board. I installed the battery and noticed the board was getting warm. I immedieily desoldered the battery from the board. I don't think it should be getting hot. I installed correctly but why is this happening? The ipod shows no water exposure. I also have some other broken 2g touchs they read 0 volts where it connects to the board. Does this mean the battery is bad? Or do I need to measure the voltage on the board on the battery? I am an electronics tech so I have a good knowledge of repairng stuff.
Thanks
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
I noticed that too when I bought one for my 4g. I Notcied it gets warm but never hot. Its gotta be a Non OEM thing
さんによる
コメントを追加
2件の回答
ベストアンサー
If the board is getting warm even though the Ipod is not on then you probably have a bridge between two of the battery terminals. If you have a multimeter check for continuity.
If the battery has 0volts then it's probably dead. Have you tried charging them? I had a battery in my ipod that didn't charge so I replaced it and the new battery (actually one from a broken Ipod) charged just fine.
The battery doesn't need to be on the board to check it's voltage.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I switched the battery to another Touch 2G and it worked fine. Except this Ipod has a white screen which I can't get rid of. The board must be bad in the first one that got hot. The board looks ok I don't see any water damage & indicator is white on headphone jack. I installed it correctly.And yes you can test a battery that is removed by checking the 2 outside terminals on the battery ribbon cable.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
thomas corcoran さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,862
