メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
Display Issue iPhone 8
Hi,
Has anybody seen an iPhone behave like this? Please view photos.
I have changed 3 original screens but it doesn’t seen to be a screen issue.
If it is a Logic board issue where should I look and what should I look for? What line?
I was hoping that somebody has seen this before and would recommend where to look to fix it. I have never seen anything like this on any phone.
Turn phone on, get one line through the apple logo across the screen. Then screen turns blue with lines all through it for a second before loading. Then when screen lock is on, tilt phone up for a second it blinks with blue screen with lines then normal home screen pops on. Like I said please view photos.
Please let me know.
There is also a ghost type issue
Cheers
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I’ve had this before and it was a problem with the screen, no matter how many times the connector is reseated it will still occur. I guarantee if you use a different screen the lines will disappear. Just make sure there isn’t any debris on the connectors and check to see if the connector is bent on the cable at all and straighten it out.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi Luke, Thanks for the info. I'll try another screen again. Hope its that, would be an easy fix. I've had the Logic Board under the microscope and can't see anything bad. I've tried 3 screens so maybe the 4th will be lucky. Cheers
If anyone else has anything to add please do.
さんによる
コメントを追加
回答を追加する
Tommy Duris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 36
