メインコンテンツにスキップ
モデル番号 A1051 / 4 もしくは6 GB ハードドライブ
iPod appears on iTunes for 1 second and then disappears
Hi everyone,
I recently purchased an iPod Mini 2nd generation off of ebay. The iPod itself works good. However, when I plug it into my computer, it is recognized for a few seconds and then disappears. I don’t believe this is an iTunes issue either, because it disappears in Finder as well.
This also isn’t an issue with my Mac either, as I connected it to my PC and the same exact problem happened. It appeared in iTunes and Windows explorer for a few seconds and then disappeared.
The “Do Not Disconnect” message appears on the screen for a few seconds as well before it disappears and reverts back to the main menu.
I opened it up and disconnected and reconnected the battery and hard drive, to no avail.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
I have five of those cables, same result as listed above with all of them.
さんによる
コメントを追加
1 件の回答
I believe the issue with this specific iPod is that the 30-pin connector on the Logic Board is damaged. While yes, it may charge, it probably doesn’t have the ability to sync data. I would suggest finding a cheap one on eBay and then replacing it yourself. (It’s actually quite a fun process!).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Conor Smyth さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 6
今までの合計 442
