メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
Home button / battery fire
Changed battery on my cousin’s 6s plus ….. it was damaged and actually caught on fire when removing it. I quickly got it out of phone , it appeared not to do too much damage. Some scorching in the left corner around and on headphone jack . I cleaned it up put new battery in , put it back together powered up everything worked EXECPT home button ….. top screen / home button was not on/near battery when it caught on fire … do I need to change charging port / headphone jack assembly….. or something else like change the entire back assembly of the phone . Need some ideas or help on what direction to go
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
If you didn’t remove the actual home button I would make sure the connector is seated properly. If it is than you have most likely damaged the flex cable or nudged a tiny component around the connector. If it is a damaged flex you will need to replace the screen.
The charge dock has nothing to do with the home button.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Thanks, Chris …..The reason I asked about the port and the surrounding area is , because in reading one of the other posts , talking about the home button , someone mentioned a broken or bad ( in my case melted ) connection causing a continuity problem that affected the home button. …. I’ve removed and reconnected everything multiple times. And when the fire took place the screen and button where 4 feet away, so the fire couldn’t have damaged the cables or connectors. Not to say I might have when I removed them with spudger . Is there anything under the headphone jack orTaptic Engine that could cause this issue? Like a ground wire or a ribbon cable …..any or next idea please
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Hoy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 93
