メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年10月16に発表されました。モデル番号はA1347でEMC番号は2840です。
Replacing BGA LPDDR3 RAM chips
I have a late 2014 mac mini with 4GB RAM. I already replaced HDD with SSD but some apps, even World of Warcraft can cause the system to hit swap. I use it as a secondary device for macOS experiments and alike from time to time… so I’m thinking about doing a bit risky mod - replacing existing Samsung K4E8E304EE-EGCE 8 Gb x 4 with chips of higher capacity and 178FBGA package - like K4E6E304EE-EGCE which are 16Gb.
Is it technically possible or is there something that would prevent such swap from working?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Thank you your information This Topic help me too much for the solve problem
Welcome to Batman999
さんによる
<br /><a href="http://batman999.com/">สล็อตออนไลน์บนมือถือ</a><br /><br />
<br /><a href="http://batman999.com/">เกมส์สล็อต</a><br /><br />
<br /><a href="http://batman999.com/">สล็อตบนมือถือ</a><br /><br />
さんによる
コメントを追加
1 件の回答
ベストアンサー
I would just get a replacement logic board which has the max memory this system can support Mac mini A1347 (Late 2014) Core i5 1.4 GHz Logic Board
Replacing the the chips is very risky! You need the proper tools and skills, you also need the schematics and board views so you can adjust the resistors so the chips are recognized. Without the documentation you’ll have a hard time figuring it out.
If you don’t have the tools and have never worked with BGA chips this would be a foolhardy endeavor.
Replace a logic board (motherboard) compatible with the Mac mini (A1347, model MGEM2LL/A) small desktop computer. Fix processing issues like unexpected shutdowns, reboots or water damage.の画像
製品
$199.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
@danj Yep - you need the schematic to reconfigure the resistor so it knows if the rMBP/MBA provides a clue.
It's not as simple and magical as people make it out to be - this is not a job for the first timer!
さんによる
Thanks, I was afraid it's more than just the LPDDR chips :) I'll see what's the local board market.
さんによる
コメントを追加
回答を追加する
Piotr さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 38
今までの合計 1,483
